- LinuxCNC
- General LinuxCNC Questions
- LinuxCNC 2.9.3 .xz image for RPi 5 is not available in the ISO directory
- 4ashishkr
19 Nov 2025 04:40 - 19 Nov 2025 04:40 #338701
by 4ashishkr
LinuxCNC 2.9.3 .xz image for RPi 5 is not available in the ISO directory was created by 4ashishkr
This image was previously available, but when I tried to reinstall it, I couldn't find the specific "
.xz" file anywhere in the ISO index.
Last edit: 19 Nov 2025 04:40 by 4ashishkr.
- unknown
- Thank you received: 323
19 Nov 2025 06:16 #338706
by unknown
Replied by unknown on topic LinuxCNC 2.9.3 .xz image for RPi 5 is not available in the ISO directory
Unfortunately the 2.9.3 image you refer to has been removed from the server.
There is a new image that has 2.9.7 and is much more raspios like.
The thread is here which has one image suitable for both the 4 & 5:
forum.linuxcnc.org/9-installing-linuxcnc...trixie-images#338181
As this is an experimental image I would be very interested in feed back.
If you need to install probe basic there are 2 extra packages to install after following the Probe Basic install instructions:
forum.linuxcnc.org/38-general-linuxcnc-q...-launch-issue#338654
If you are not installing Probe Basic there is no need for these packages.
- 4ashishkr
21 Nov 2025 05:25 #338857
by 4ashishkr
Replied by 4ashishkr on topic LinuxCNC 2.9.3 .xz image for RPi 5 is not available in the ISO directory
Thanks for reply.
Any idea why it was removed ?
I have being using it for long. Any known alternative link for the same ?
- unknown
21 Nov 2025 06:10 #338859
by unknown
No idea why it was removed.
I've only been involved in creating the images from 2.9.4 and the above experimental image.
The 2.9.4 image is based on Bookworm & 2.9.7 is Trixie based.
28 Nov 2025 21:41 #339401
Replied by andypugh on topic LinuxCNC 2.9.3 .xz image for RPi 5 is not available in the ISO directory
I don't know why 2.9.3 was removed either,[1] but 2.9.7 should be better. (basically just the same, but with bugfixes)
And if you have previously down;oaded the 2.9.3 image, don't you still have it somewhere?
[1] And it's almost certainly me who did it
- LinuxCNC
Time to create page: 0.271 seconds
