- LinuxCNC
- General LinuxCNC Questions
- Moderator Notice Regarding Links To Unsanctioned Mirrors - Clarfication.
- unknown
- Thank you received: 323
16 Dec 2025 01:12 #340161
by unknown
Moderator Notice Regarding Links To Unsanctioned Mirrors - Clarfication. was created by unknown
Does this mean I should remove the link to the RPi5/4 images I've been working on. Which I have no issue with if this is the way it should be.
Cheers
Rob
Cheers
Rob
- unknown
16 Dec 2025 01:54 #340166
by unknown
Replied by unknown on topic Moderator Notice Regarding Links To Unsanctioned Mirrors - Clarfication.
That is not the image I'm referring to. That image has been uploaded via one of the mods.
I don't not have access to any of the Linuxcnc resources. Even if I did I would ensure that the image was vetted and approved by others.
- snowgoer540
- Thank you received: 907
16 Dec 2025 02:56 #340167
by snowgoer540
If you mean the GitHub link, no, you don’t need to remove it. It’s not a mirror. It’s your own work and it’s been communicated as such.
Replied by snowgoer540 on topic Moderator Notice Regarding Links To Unsanctioned Mirrors - Clarfication.
Cheers
Rob
- unknown
16 Dec 2025 04:11 #340169
by unknown
Thanking you kindly sir.
The following user(s) said Thank You: rodw, snowgoer540
- LinuxCNC
