Python LinuxCNC module
- hhscott
- Thank you received: 15
29 Dec 2025 16:19 - 30 Dec 2025 01:07 #340688
by hhscott
Python LinuxCNC module was created by hhscott
I am wanting to write a couple of simple python3 scripts to automate some functions in LinuxCNC using the python linuxcnc module to send NML messages. I did this several years ago for another project and it was very successful. In this new application I am using a pi5 8GB with a Mesa 7i96s running Trixie 2.9.7. The basic installation is working well and the CNC is operating great so far (without any python automation).
I am a little confused about using python on Debian Trixie. When I try to install a package I get errors and the terminal prompts that I should use a virtual environment for python and packages. If I do this, will my python scripts still connect to the running instance of LinuxCNC? Please help me understand the basic structure for using python on the Trixie OS with LinuxCNC.
Thank you,
HH
Thank you,
HH
Last edit: 30 Dec 2025 01:07 by hhscott.
- Thank you received: 4154
29 Dec 2025 23:17 #340698
Replied by rodw on topic Python LinuxCNC module
yes this is a requirement now. nonstandard modules require a virtual environment (venv) in a folder. Google python venv
The following user(s) said Thank You: NWE
Time to create page: 0.410 seconds
