MESA 1I76EU Firmware
31 Dec 2025 04:32 - 31 Dec 2025 23:14 #340757 by Bendandsend
MESA 1I76EU Firmware was created by Bendandsend
Hi all,
I’m setting up a Mesa 7i76E (Ethernet) with a single 7i76 smart-serial I/O board on Debian 12 / LinuxCNC 2.9 and appear to be stuck due to missing FPGA firmware.
LinuxCNC installs and runs fine, PnCconf completes, and the board is reachable over Ethernet, but field outputs never work:HAL signals link to hm2_7i76e.0.7i76.0.output-00halcmd show pin | grep 7i76 returns nothingdmesg shows no smart-serial / 7i76 detectedEstop / stepgens work, but no field I/O activity/lib/firmware/mesa does not exist, and I can’t install linuxcnc-firmware-mesa because the machine is offline and buildbot appears to be down.
I’m looking for a known-good firmware file for this setup (likely 7i76e_7i76x1.bit), or a working mirror / source for Mesa firmware on LinuxCNC 2.9.
Any pointers appreciated — happy to provide logs if needed.
 Thanks!
Tim.
Last edit: 31 Dec 2025 23:14 by Bendandsend.
  • Moderator
  • Moderator
31 Dec 2025 13:37 #340769 by tommylight
Replied by tommylight on topic MESA 1I76EU Firmware
Replied to other topic with seemingly same content.
Time to create page: 0.200 seconds
