RPi CM5 on Mesa Ethernet 7i95
  • PHILCOAST
  • Topic Author
  • New Member
  • New Member
9 months 3 weeks ago #341104 by PHILCOAST
RPi CM5 on Mesa Ethernet 7i95 was created by PHILCOAST
Hello, I am testing LinuxCNC 2.9.7 (official Raspberry Pi 4/5 image, Debian Trixie, uspace) on a Raspberry Pi Compute Module 5 (CM5) with a Mesa 7i95 Ethernet card.
The same LinuxCNC version, Mesa card, cable, and network configuration work on another Raspberry Pi platform, but on CM5: • eth0 stays NO-CARRIER • ethtool eth0 shows Link detected: no • Forcing speed/duplex has no effect • RP1 PCIe device is detected in kernel logs Network: • eth0: 10.10.10.1/24 • Mesa: 10.10.10.10
Is CM5 fully supported by the current LinuxCNC Raspberry Pi 4/5 image, or is newer kernel / device-tree support required for RP1 Ethernet on CM5? Thank you.
9 months 3 weeks ago - 9 months 3 weeks ago #341112 by NWE
Replied by NWE on topic RPi CM5 on Mesa Ethernet 7i95
Checking the datasheets:
The Pi5 and CM5 both use the BCM2712 CPU. The CM5 uses the Broadcom BCM54210PE ethernet phy ic. I'm having a bit of trouble finding concrete info on what the Pi5 has, but I see my Pi 5 datasheet in the photo of the Pi 5 it has a BCM54213PE ethernet phy ic soldered near its ethernet connector. According to a quick look at the datasheets, those two chips appear to be interchangable.
In other words Pi 5 = CM5 as far as network drivers is concerned.
I think you could run in a terminal:
lspci -k
to determine whether the correct drivers loaded. It should report the same modules for the network as it does on your Pi 5.
On the other hand, maybe there is a connection problem between the I/O board and the CM5, is the CM5 seated correctly, and the connections clean? One thing I'd try is carefully disconnecting then re-seating the CM5 on the I/O board, it could make a difference.
Last edit: 9 months 3 weeks ago by NWE.
The following user(s) said Thank You: PHILCOAST
9 months 3 weeks ago #341126 by unknown
Replied by unknown on topic RPi CM5 on Mesa Ethernet 7i95
Please use this image:
drive.google.com/file/d/1CoO_2y7iDTwtubG...VSw/view?usp=sharing
Usually a no carrier issue would be a cable issue between the RPi5 & Mesa board (the drivers have been loaded), has the Mesa board booted correctly ?
Bear in mind that the kernel used is directly from the Raspberry Pi repos, ie it is not a custom kernel other than being RT capable. The RPi kernel build instruction make no differentiation between any of the "5" series. The all use the same kernel. Neither is there special options related to ethernet for the CM5 in the config.txt file.
It may help if you can provide a link to the carrier board.
The best place for any issues relating to the current Trixie images is at the link below as I don't use the forum as often as I used to. There is no need to raise an issue as I'm aware of it.
github.com/ozzyrob/linuxcnc-rpi-2.9.7-image-issues
The following user(s) said Thank You: PHILCOAST, NWE
  • PHILCOAST
  • Topic Author
  • New Member
  • New Member
9 months 3 weeks ago #341171 by PHILCOAST
Replied by PHILCOAST on topic RPi CM5 on Mesa Ethernet 7i95
Thanks for the test image.It solved the issue on CM5-7i95 detected and linuxcnc running with hm2_eth and working I/O.Much appreciated.
Time to create page: 0.256 seconds
