Startup Question
11 Jan 2026 04:49 #341258 by hhscott
Startup Question was created by hhscott
Simple question that I cannot seem to locate the answer:
No matter what offset I was using when I shutdown LinuxCNC I want my DROs to read 0 after I restart and then home. I can do this with the Touch-Off button in Axis but how do I set my INI/HAL file to clear offsets when LinuxCNC restarts?
Of is there a mdi input that would have the same outcome?
Thanks,
HH
11 Jan 2026 06:15 #341265 by MaHa
Replied by MaHa on topic Startup Question
yourmachine.ini  file,  in  [TRAJ]  section  POSITION_FILE = posfile.txt   stores machine positions at shutdown. If this is not set, the machine starts with all axes set to zero
11 Jan 2026 06:38 #341267 by hhscott
Replied by hhscott on topic Startup Question
Great! Thank you
Time to create page: 0.134 seconds
