Problem with Mesa 7i96s and spindle control
- Mark Kraus
27 Jan 2026 13:25 #341992
by Mark Kraus
Problem with Mesa 7i96s and spindle control was created by Mark Kraus
What is the proper way to send a hal and ini file?
- Thank you received: 7486
27 Jan 2026 13:30 #341993
Replied by tommylight on topic Problem with Mesa 7i96s and spindle control
Just attach them below the editor, like this
- Mark Kraus
27 Jan 2026 16:03 - 28 Jan 2026 03:53 #342004
by Mark Kraus
Replied by Mark Kraus on topic Problem with Mesa 7i96s and spindle control
Last edit: 28 Jan 2026 03:53 by Mark Kraus. Reason: Things changed
- Mark Kraus
28 Jan 2026 15:51 #342084
by Mark Kraus
- Mark Kraus
28 Jan 2026 17:59 #342091
by Mark Kraus
- Thank you received: 2176
29 Jan 2026 09:15 - 29 Jan 2026 09:27 #342151
Replied by Aciera on topic Problem with Mesa 7i96s and spindle control
1. Please stop changing the 'Subject' descriptor of the thread when you add new posts. Makes it really confusing for people.
2.
We might be able to if you actually told us what your are trying to do. You maybe want to connect a encoder to your spindle and are not getting the 'spindle-at-speed' signal to work in hal? Hardware used (a MESA board maybe)? If so which one?
2.
Still have no clue what could be wrong. The at speed light comes on but nothing in halshow. Could someone please guide me?
Last edit: 29 Jan 2026 09:27 by Aciera.
- Mark Kraus
29 Jan 2026 14:04 #342157
by Mark Kraus
Thank you for responding. I am sorry I did not include more info. My board is a 7i96s and now I have encoder feedback. Turns out there was a wiring error. Now I have negative values and way off when doing M3 command. I set my amt102-v to 1024ppr so i was using 4096 in pncconf. I am new to this so using pncconf appeals to me for as much of the build as I can.
I am curious if the mesa config is better than the pncconf and can I make a separate profile in it? I was working on getting the encoder working and at the same time I changed some settings and now my spindle does not work. I have the m3 come on and the vfd shows hz rising and then stabalizing but the fan on the vfd does not come on and i have no 3 phase coming out. I should not have been messing with the wiring and at the same time changing settings and will try not to do that again, but for now I dont know which one it is, the settings in pncconf or a wiring issue.
29 Jan 2026 14:24 #342158
I changed your Topic title to something more descriptive.
You might want to give some more information on your vfd and how you have wired it to your 7i96s.
- Thank you received: 5328
29 Jan 2026 17:43 #342162
Replied by PCW on topic Problem with Mesa 7i96s and spindle control
One way to help diagnose this (assuming it's a hal issue) is to run
LinuxCNC, and then turn on the spindle at 1/2 speed.
Then, in a terminal window, type:
halcmd show all | grep spin > spindle.txt
and post the created spindle.txt file here.
Time to create page: 0.762 seconds
