Problem with Mesa 7i96s and spindle control
9 months 3 days ago #342157 by Mark Kraus
Thank you for responding. I am sorry I did not include more info. My board is a 7i96s and now I have encoder feedback. Turns out there was a wiring error. Now I have negative values and way off when doing M3 command. I set my amt102-v to 1024ppr so i was using 4096 in pncconf. I am new to this so using pncconf appeals to me for as much of the build as I can.
I am curious if the mesa config is better than the pncconf and can I make a separate profile in it? I was working on getting the encoder working and at the same time I changed some settings and now my spindle does not work. I have the m3 come on and the vfd shows hz rising and then stabalizing but the fan on the vfd does not come on and i have no 3 phase coming out. I should not have been messing with the wiring and at the same time changing settings and will try not to do that again, but for now I dont know which one it is, the settings in pncconf or a wiring issue.
9 months 3 days ago #342158 by Aciera
I changed your Topic title to something more descriptive.
You might want to give some more information on your vfd and how you have wired it to your 7i96s.
9 months 3 days ago #342162 by PCW
One way to help diagnose this (assuming it's a hal issue)  is to run
LinuxCNC, and then turn on the spindle at 1/2 speed.
Then, in a terminal window, type:
halcmd show all | grep spin > spindle.txt
and post the created spindle.txt file here.
Time to create page: 0.148 seconds
