- Thank you received: 47
Yes, I'm using Beckhoff I/O strictly as remote I/O, all my logic exists in the pc running LinuxCNCJust to be clear, in your setup you are using Beckhoff EtherCAT I/O as remote I/O, but without a Beckhoff PLC runtime (e.g. TwinCAT PLC), correct?
I've always had good results with AutomationDirect's Click PLC's. But I've been disappointed with the reliability of their Productivity 2000 and also their BRX models. Maybe it was just bad luck. I've finally retrofitted most of my higher end AutomationDirect PLC's but those Clicks sure don't seem to make much trouble. Still I don't care for ladder logic.Admittedly, the Click PLCs are fairly 'low-end', so higher-end PLC's likely have more sophisticated onboard motion control features.
I think of this: LinuxCNC has capability to be operated by the user, entirely using keyboard+mouse+monitor, at opposite extreme it can have external I/O wired to physical buttons, switches and dials for operator control without any keyboard+mouse+monitor if you wish.This is similar to how many industrial robotic cells are structured, where a dedicated motion controller handles paths, and a PLC controls the cell logic and operator interaction.
So the question is not whether LinuxCNC can do everything, but how others have structured a clean responsibility boundary between a real PLC and LinuxCNC in production machines.
Any practical examples along those lines would be appreciated.
