Motor timing help
  • nicklego
  • nicklego's Avatar Topic Author
  • New Member
  • New Member
31 Jan 2026 21:27 #342264 by nicklego
Motor timing help was created by nicklego
Hi, I'm very new to CNC, and I have a Maxnc15CL from around the year 2000 and am using a Raspberry Pi 5 to communicate with it using LinuxCNC. The Pi 5 has a parallel port hat from Byte 2 Bot, and I'm able to control the spindle, detect the limit switches, enable the motor encoder feedback loop, and make the motors make noise when I tell the axis to move. I suspect that the motor timing is off, but im not too sure if when I change the values, if it's getting closer or further away from actually moving. If anyone has any ideas on how to make this work, I would greatly appreciate it, and im leaving my hal file and .ini file below. Thank you
File Name: V3Maxnc_20...1-31.hal
File Size:9 KB
File Name: V3Maxnc_20...1-31.ini
File Size:3 KB
Time to create page: 0.055 seconds
