Raspberry pi 5 freze
- krille
02 Feb 2026 18:08 #342321
by krille
Raspberry pi 5 freze was created by krille
Hi and so much thanks to the people made all the work with the linuxcnc for raspberry pi 5 ,its a great job.
I have downloaded 4.8.9 and it's a great distro working so fine from beguining and today after a week or two the program stop and freze after 5-10 min. I can still run the stepper from the keyboard and the speedometer on the spindle is i ok and run but the rest of the program stop . the only way to go on is a hard rebot and then it start fine and then the problem starts again . Are there people who can help me in the right direction
I use the byte2bot board in Lathe config. /krister
- Online
- Thank you received: 7491
02 Feb 2026 18:23 #342322
Replied by tommylight on topic Raspberry pi 5 freze
Can you run LinuxCNC from the terminal and copy/paste the errors reported when that happens?
Usually linuxcnc -l should start last used config.
- krille
10 Feb 2026 13:35 #342769
by krille
Replied by krille on topic Raspberry pi 5 freze
Hi I have difficults to use terminal its a little bit over my competens in linux ,but I change the cordless mouse to a mouse with a cord and after this the program are esier to work with the most off lagging diasapeard and I also changesd the Base period to 150000 and the Servo_period to 1200000 , after that i open up the idex setup file and set it to setp lowpass.0.gain 0.01 .
Its work great two weeks until today when the program freez again , after hard reboot it starts again .
One strange thing is during running a program nothing happens but if I take a coffebreak and the program idle the famos latensy varning came up on the screen . yors sinserly Krister
Time to create page: 0.098 seconds
