Joint following error all axis
12 Feb 2026 17:00 #342851 by MarcNL
Joint following error all axis was created by MarcNL
Hi all,
I've been running a 3 axis stepper cnc voor a couple of years now. Everything was working fine 4 days ago. Today after powering on when I try to jog or G28 I get joint following errors on all axis. If I lower the feedrate substantially I can jog manually, bur starting any job fails joint 'x' following error. I havent made any changes to hall or ini file. Can anyone point me in the right direction for troubleshooting?
Thanks in advance.
  • Moderator
  • Moderator
12 Feb 2026 20:51 #342861 by tommylight
Replied by tommylight on topic Joint following error all axis
Does LinuxCNC complain about latency when starting?
The following user(s) said Thank You: MarcNL
12 Feb 2026 21:29 #342863 by MarcNL
Replied by MarcNL on topic Joint following error all axis
No, no other errors. Only joint following error.
  • Moderator
  • Moderator
12 Feb 2026 22:12 #342866 by tommylight
What PC?
What interface, parallel port or Mesa or Pico systems or...?
What drives? Step/dir or analog or EtherCAT?
What do you expect G28 to do? It is not homing as in 3D printers.
Upload the hal and ini files here so we can have a look.
12 Feb 2026 22:25 #342868 by MarcNL
The pc is a HP Z400; workstation (quad core xeon with 8 gb memory and ssd). The interface is parallel port with step/dir. G28 moves all axis to machine zero.
I will upload the hal and ini files tomorrow (it's night time overhere). But I don't think that's the problem because it was working perfectly for the last couple of years.
13 Feb 2026 13:29 #342886 by MarcNL
Today all is functioning normally again. Ran a 30 minutes program without errors. So I don't know what happened yesterday, maybe I need a new pc.
  • Moderator
  • Moderator
13 Feb 2026 13:35 #342888 by tommylight
Z400 are very good, so i would not change it, but in case you have issues again, try removing memory modules, never happened to me on a Z400, but happens sometimes on Z420 and happens a lot on Z600, at boot reports of memory issues that mostly disappear on their own.
13 Feb 2026 14:08 #342890 by MarcNL
Okay, will try that when problems retturn. Thanks!
  • Moderator
  • Moderator
13 Feb 2026 20:03 #342909 by tommylight
You are welcomed, always.
