- LinuxCNC
- General LinuxCNC Questions
- Retrofit 7 ton HOMAG with Rexroth motors and drives - mesa 7i97t
- Nkbhvid
13 Feb 2026 21:35 #342915
by Nkbhvid
Replied by Nkbhvid on topic Retrofit 7 ton HOMAG with Rexroth motors and drives - mesa 7i97t
“Also insure the all PWM enables are true, and all PWM values are 0”
Should I define this in HAL?
- Thank you received: 5329
13 Feb 2026 21:44 #342916
Replied by PCW on topic Retrofit 7 ton HOMAG with Rexroth motors and drives - mesa 7i97t
No, if you set all PID values to 0 in the .ini file, run linuxcnc
and set LinuxCNC into the machine-on state, all PWM values will be 0
and the PWM enables should all be true (at least for the joints enabled in the hal file)
- LinuxCNC
Time to create page: 0.095 seconds
