HDD vs. SSD
  • landoneilers
  • landoneilers's Avatar Topic Author
  • Visitor
  • Visitor
18 Feb 2026 21:11 #343164 by landoneilers
HDD vs. SSD was created by landoneilers
I am planning to install LinuxCNC 2.9.8 for a parallel port setup (I know Wheezy is probably better, but I need it to be as user-friendly and modern as possible).
I have a bunch of disks I can install it to:
500GB WD Blue HDD (16MB cache) (The ideal choice, I have like 6 extra ones)
256 SanDisk SSD (I only have 4).
500GB WD Blue HDD (32MB cache) (Less plentiful than the 16MB caache drives, but I don't really need this drive for anything).
Which drive would be the best choice for latency.
Bootup time is irrelevant to me, latency is really my only concern.
I will use this PC almost exclusively for machine control, except to download nc files perhaps.
18 Feb 2026 21:19 #343166 by tommylight
Replied by tommylight on topic HDD vs. SSD
Get an old mainboard/CPU/MEM and plug all 6 to it, see bellow
Use for LinuxCNC machines, much better latency/access times compared to mechanical drives, and much faster.
Use this one to install TrueNAS and plug it into the same old PC mentioned above with the other 6 drives, you get a nice 2.5TB NAS with fault tolerance for one failed drive.
  • landoneilers
  • Visitor
  • Visitor
18 Feb 2026 21:21 #343169 by landoneilers
Replied by landoneilers on topic HDD vs. SSD
I have never seen a motherboard with more than 4 SATA ports.
I don't really need NAS, though that is a cool idea, I suppose.
  • landoneilers
  • Visitor
  • Visitor
18 Feb 2026 21:24 #343170 by landoneilers
Why TrueNAS over FreeBSD?
(I know TrueNAS is based on FreeBSD, but still)
18 Feb 2026 21:26 #343171 by rodw
Replied by rodw on topic HDD vs. SSD
HDD read/write has no impact on latency.which measures hardware performance, network latency is important for mesa/ethercat systems.
The buffering of gcode will be sufficient to cover HDD speed.
Using a SSD is  a great boost in performance and I usually install one when refurbing a machine. Recently I didn't on a 8 core i7 & I really noticed how much longer Debian took to install.
Use the one you say is ideal
The following user(s) said Thank You: landoneilers
  • landoneilers
  • Visitor
  • Visitor
18 Feb 2026 21:35 #343174 by landoneilers
Does HDD cache size have any impact?
18 Feb 2026 21:57 #343176 by tommylight
I've always had with more than 4 as they also had a separate SATA controller with RAID, still have 2 with 6 SATA ports, and all Enterpise towers also have 6 or 8 ports (HP Z420 and Z600)
18 Feb 2026 21:58 #343177 by tommylight
It's not, new version is Debian as far as i can gather from the boot time info.
  • landoneilers
  • Visitor
  • Visitor
18 Feb 2026 22:11 #343178 by landoneilers
Weird.
FreeBSD seems faster.
Why would they switch to Debian?
  • landoneilers
  • Visitor
  • Visitor
18 Feb 2026 22:12 #343179 by landoneilers
I will install LinuxCNC onto a random (not-super-ancient) HDD.
I hope it goes well.
Time to create page: 0.098 seconds
