M codes for a second spindle?
22 Feb 2026 17:48 #343316 by liutas4x4
M codes for a second spindle? was created by liutas4x4
Hi.
Are them already preset in project or them should be created by myself?
/eugenius
22 Feb 2026 18:47 #343318 by michaeln
Replied by michaeln on topic M codes for a second spindle?
23 Feb 2026 19:52 #343360 by liutas4x4
Replied by liutas4x4 on topic M codes for a second spindle?
Checked. It was about relays and laser, nothing about rotation of the motor with preset speed, like M3 S1000.
23 Feb 2026 20:36 #343364 by tommylight
Replied by tommylight on topic M codes for a second spindle?
Try
M3 $1 S1000
Since LinuxCNC 2.8 (i think) there is built in support for multiple spindles, the $n should be the G-code controlling the spindle number where n is the spindle number starting from 0 (zero), so $0 is the default first spindle, then $1 is the second spindle, etc.
linuxcnc.org/docs/html/examples/spindle.html
linuxcnc.org/docs/stable/html/gcode/othe...ec:set-spindle-speed
The following user(s) said Thank You: liutas4x4
23 Feb 2026 21:29 - 23 Feb 2026 21:30 #343367 by liutas4x4
Sounds good. I will try it. Thank you.
Last edit: 23 Feb 2026 21:30 by liutas4x4. Reason: tipo
25 Feb 2026 19:44 #343497 by liutas4x4
It is working. Thanks to you and @dm17ry -- it runs easyli.
25 Feb 2026 22:51 #343503 by tommylight
You are welcomed, always, and thank you for reporting back.
Time to create page: 0.078 seconds
