- Thank you received: 595
Looking at it in this way, the Regler and Bremse being two distinct entities, what you're suggesting may be the case."Reglerfreigabe" is not brake interface, it is drive enable. That is the signal to enable the muscle power of your servo drives. Could it be that you are releasing the brakes before powering up the drives output stages? That would explain there being no holding torque. Linxucnc sees this Ferror but can't do anything about it as it is commanding a turned off power stage. Seems lucky there is some internal emergency mode in the driver which is catching it after only 10mm. Maybe it does that by ignoring the inactive drive enable, and powering up the output stage to arrest motion?
On my set up, the screw up I made was to enable the drives output stage with the "machine on" signal, but to release the brake when I release my finger from the machine on button, so I had drive fighting the brake for the duration that the button was pressed.
I'm coming to the conclusion that the Regler power on electrically triggers the brake release. In the page I've attached, that's what it seems like. So it is probably not possible for me to interface them separately. Then again, the brake release having the regulator (7K2) as a prerequisite, should ensure the brake isn't released without the drive being powered on, no?
However, I do not think I have a signal for the brake itself. The only output signals from the controller to the drives I have are — Reglerfreigabe X-Y-Z Achse, Reglerfreigabe Hauptantrieb, Anwahl Werkzeugspanner, Kühlmittel, ...many empty ones..., CNC-Fehlermeldung, ... many empty ones..., CNC-Betriebsbereit. So that's essentially 5 signals with 29 unoccupied ones.
Do you think there may be a way to interface the brake separately? Right now, it seems that is handled internally by the drive, considering that it releases essentially immediately along with the drive enable — so much so that I had thought they were both one singular operation. An internal servo parameter? But I didn't find any brake related parameters in the doc. I do see some BR1 and BR2 signals in the Vorschubantrieb page (attached). I will investigate.
Thanks for sticking with me through this. B and C are nothing but encoders, their movement is done manually by the operator.Regler (DE) = servo driver module (EN). On my machine it is the Indramat, on yours it is the Simodrive 611.
7k2 is not the servo driver is it? DMG terminology would be that 7k2 is a 24V control relay. On my machine the servo drivers (the indramats) are called 7A1 and 7A2. On yours the Z axis drive is 7A5 (you probably have three separate servo drives on the axis, another on the spindle, and maybe a fifth on a C axis? I only have two.
The brake releases as soon as the 7K2 relay closes. What is the signal chain which energises the 7K2 coil? That needs to happen at the same time as the Reglerfreigabe is commanded through the X331 terminal block on your Simmodrive. What are the three signals in the X331 terminal block? I would guess the Reglerfreigabe signal , a gnd and maybe the third wire in that cable is a "driver enabled" feedback to the CNC controller. Alternatively, it could be a "Servo Drive Fault" signal.
How did you tie them into LinuxCNC? You need to be setting whatever pin in X331 is the drive enable to active, at that same time as you are energising the 7K2 relay.
