pin locations
13 Mar 2026 21:53 #344228 by natas01
Replied by natas01 on topic pin locations
Just trying to hook up the spindle.
And don’t know what im doing. Lol
I can wire a overhead crane but this keeps me scratching my head
13 Mar 2026 22:09 #344229 by PCW
Replied by PCW on topic pin locations
All the spindle control stuff would be on TB3
(the SSR outputs for FOR and REV and PWM for the speed control)
14 Mar 2026 19:20 - 14 Mar 2026 19:44 #344270 by natas01
ok im starting to understand
but not the speed control PWM?
Last edit: 14 Mar 2026 19:44 by natas01.
14 Mar 2026 19:57 #344271 by PCW
Sorry, I was wrong:
The SSRs (that you would use for spindle FOR/REV) are on TB3,
but the PWM controlled analog output is on TB2
The following user(s) said Thank You: natas01
14 Mar 2026 20:37 - 14 Mar 2026 20:37 #344272 by natas01
so would the spindle enable be the variable voltage
Last edit: 14 Mar 2026 20:37 by natas01.
14 Mar 2026 21:16 #344273 by PCW
Not sure what you mean here
At the physical interface level there is no enable, but rather FWD and REV
14 Mar 2026 21:39 #344275 by natas01
The 0-10 volt to control the speed
14 Mar 2026 21:41 #344276 by tommylight
Replied by tommylight on topic pin locations
No, spindle enable is just enabling the VFD, speed is controlled by variable voltage.
14 Mar 2026 22:23 - 14 Mar 2026 23:02 #344277 by natas01
Theres no vfd there’s a image of what im trying to hook up in a earlier post
im trying to find out how to get variable voltage
Last edit: 14 Mar 2026 23:02 by natas01.
15 Mar 2026 02:01 #344290 by PCW
To get the variable voltage, you set up the TB2 PWM output for spindle use in pncconf
The 7I96S manual shows the TB2 pinout of the analog output
7I96S Spindle + goes to a 10 or 12V supply (on a VFD this comes from the VFD itself)
7I96S Spindle out is the 0--10V analog voltage that goes to the Drives VIN
7I96S Spindle- goes to the drives COM pin and the negative pin of the 10 or 12V supply
Time to create page: 0.138 seconds
