xhc-hb04 does not communicate
- billykid
- Thank you received: 83
13 Mar 2026 12:19 #344206
by billykid
xhc-hb04 does not communicate was created by billykid
Good morning, I bought an xhc-hb04 because mine had fallen and the wheel didn't turn well, but it still works. When the new one arrived, I immediately noticed that it stays on even when the PC is off, which the old one didn't. It's detected because if I remove the LinuxCNC dongle, it gives me an error. The working one has a chrome power button, while the new one has a plastic button. I think it's defective. What do you think?
24 Mar 2026 12:37 #344669
Replied by andypugh on topic xhc-hb04 does not communicate
Does it have the same USB ID as the previous one? Possibly you need to change the USB identifier in the config files, or possibly the udev rules.
linuxcnc.org/docs/html/man/man1/xhc-hb04.1.html
The following user(s) said Thank You: billykid
- billykid
26 Mar 2026 12:45 #344771
by billykid
Replied by billykid on topic xhc-hb04 does not communicate
Thanks, after a few tries I managed to get it to work, but only for a few minutes. Then it would disconnect and reconnect until it froze completely. Now the USB stick is no longer detected and it also blocks the mouse and keyboard when I insert it.
06 Apr 2026 17:15 #345235
There have been recent updates to the driver. Which LinuxCNC version are you using?
- billykid
10 Apr 2026 16:57 #345399
by billykid
Thanks, but the USB stick was really broken and it blocks any PC it's plugged into. I'm using the handwheel to modify it with an ESP32.
Time to create page: 0.116 seconds
