Debian Trixie and "onboard" on-screen keyboard - missing at-spi2-core
  • rdtsc
  • rdtsc's Avatar Topic Author
  • Senior Member
  • Senior Member
14 Mar 2026 13:17 #344253 by rdtsc
Hi, just a note if you try
sudo apt install onboard
to use the on-screen keyboard, this will not work.  It results in:
(onboard:1747): dbind-ERROR **: 09:00:29.341: AT-SPI: Couldn't connect to accessibility bus. Is at-spi-bus-launcher running?
Trace/breakpoint trap
This is due to an unmet dependency.
at-spi2-common
is included, but not
at-spi2-core
.  Install that package also and onboard will then work.
The following user(s) said Thank You: andypugh, tommylight
Time to create page: 0.103 seconds
