W axis machine config
- Yannis
- Thank you received: 4
20 Mar 2026 13:28 #344547
by Yannis
Dear
I m trying to configure a 5 axis machine with W axis for the movment of the machine according to the B,C axis anglew move
the linuxcnc start normaly with no errors but the F1,F2 buttons are not working to start the machine
lcnc 2.8.4-1-gb7824717b on w
The machine works with diferent configuration normaly
Any sugestions?
W axis machine config was created by Yannis
Dear
Any sugestions?
25 Mar 2026 12:29 #344716
Replied by andypugh on topic W axis machine config
Try starting LinuxCNC from the command line and see if there is any useful output in the terminal.
Also, load halshow (With Axis this is "show machine config" in the "machine" menu , as far as I recall) and check that these connections exist:
From your HAL file:
From your HAL file:
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
The following user(s) said Thank You: Yannis
- Yannis
27 Mar 2026 07:07 #344814
by Yannis
Replied by Yannis on topic W axis machine config
The signals looks ok
Also on the WATCH tablet the virtual led for e-stop and machine enable are working fine
06 Apr 2026 17:19 #345237
And you see the pin iocontrol.0.emc-enable-in toggling high?
Maybe something odd with the amp-fault pin for the W-axis?
joint.N.amp-fault-in
Time to create page: 0.171 seconds
