LinuxCNC not working with new 64-bit desktop and parallel port
05 Apr 2026 22:20 #345213 by clayton2ndtry
I wanted a more modern version than 2.7.15, mostly because the builrtn browser was so ancient that many websites refused to work with it. 2.9.8 needed a 64-bit processor. Someone gave me a 64-bit desktop. I only needed to put a PCIe parallel port in it. Okay, 2.9.8 installed in a system with gobs of RAM and SSD storage. Everything is connected as it was before but no axes move. When I run latency test, I get max jitter of 30,381 on Servo thread. 60,354 on Base Thread.
I wonder if the parallel port card is defective. How would I test that?
06 Apr 2026 08:05 #345218 by HansU
You could first check if your parallel port is properly installed.
The command
lspci
should list a device with LPC Controller or LPT Controller or similar.
06 Apr 2026 14:22 #345224 by clayton2ndtry
Searching for guidance gave me only a sensation that the parallel port might have the wrong address. Supergrok saved the day. It helped me find that the built-in parallel poets are at 0x3F8. This rang a bell from when I wrote a terminate-and-stay-resident PC-DOS (stop laughing) program that intercepted data going to the parallel port and converted Epson control codes to Postscript. It was wonderfully elegant in how it allowed programs with no Postscript support to use Apple LaserWriters
Changing one of the LinuxCNC setup files to talk to the parallel printer at 0xC010 and problem is solved.
07 Apr 2026 07:53 #345257 by rodw
This rang a bell from when I wrote a terminate-and-stay-resident PC-DOS (stop laughing) program that intercepted data.
I did something similar but it trickled point of sale transactions out of a cash register to accounting software (And I got paid for it!)
Time to create page: 0.211 seconds
