Gibbscam Post Processor
- Sierevello
05 Apr 2026 21:49 #345217
by Sierevello
Gibbscam Post Processor was created by Sierevello
I am converting my machine to Linuxcnc and currently use Gibbscam. Does anyone else here use Gibbscam and is there a current post processer for Gibbscam for use with Linuxcnc.
Thank You,
Steve
Thank You,
Steve
The following user(s) said Thank You: rhscdn
- Thank you received: 7506
03 May 2026 00:01 #346127
Replied by tommylight on topic Gibbscam Post Processor
Did you check if it has a post fro EMC2 as that was the old name for LinuxCNC?
Post processors should be fairly easy to edit/modify, so you can give that a try.
Time to create page: 0.221 seconds
