In Need of 3 axis mill sample program
14 Apr 2026 17:56 #345547 by Sierevello
In Need of 3 axis mill sample program was created by Sierevello
Good Afternoon,
I am in need of a 3 axis milling sample program. I am converting my Anilam Crusader M 3 axis mill to LinuxCNC. I use Gibbscam and in order to help me with the post processor they need a sample program that contains gcode that generate lines, circles, tool changes, etc. I sent them a link to the LinuxCNC G Code catalog. Any help is greatly appreciated.
Thank You,
Steve in Indy
14 Apr 2026 21:55 #345556 by spumco
Replied by spumco on topic In Need of 3 axis mill sample program
You could send them one of the sample programs that is installed with LCNC.  Like chips.ngc.
Keep in mind that your tool changer is going to be specific to your machine and LCNC configuration, especially if the tool change sequence requires anything beyond "M6 Tn G43" in it.
Example - does your machine require the post to raise the head to a safe point before the tool change M-code is commanded, or is that part of the internal change sequence?
Same for any custom or machine-specific M-codes.
14 Apr 2026 22:34 #345559 by Sierevello
Replied by Sierevello on topic In Need of 3 axis mill sample program
No. The tool change position has to be commanded in the Gcode. The tool change on this mill is manual.
Thank You!
-Steve
