Connecting Vers WL v.3.1
- Alexf2a
25 Apr 2026 12:50 #345915
by Alexf2a
Connecting Vers WL v.3.1 was created by Alexf2a
Hello. Could you tell me how to connect the old model centerfinder vers.ge/ru/blog/archive/vers-wl-v31 to the MESA 7I76 in the 5i25 and 7i 85s configurations? I supply the 7I76 with 5 and 24 volts, but the Vers WL v.3.1 requires 5-12 volts. Can I reduce the voltage from 24 to 10 volts using the XL4015E unit?
The Vers WL v.3.1 worked well on the MACH3, but it only had a 5 volt supply.
Thank you.
Thank you.
- jetbadger
25 Apr 2026 16:21 #345920
by jetbadger
Replied by jetbadger on topic Connecting Vers WL v.3.1
The voltage range of the Mesa inputs is something like 5-32v and for the supply you could either take the 5V from encoder/stepdir outputs of the Mesa or have a separate small 9V or something like that psu just for the probe. Just connect the 0V together with Mesa field power 0V
Time to create page: 0.199 seconds
