MESA card (LAN) failing to connect.
- Accipiter
5 months 4 weeks ago #346109
by Accipiter
Replied by Accipiter on topic MESA card (LAN) failing to connect.
Please advise if this is an appropriate response. Thank you.
- Thank you received: 5334
5 months 4 weeks ago #346111
Replied by PCW on topic MESA card (LAN) failing to connect.
No, it's not set in the IP address range of the FPGA card
I would set the host address to 10.10.10.100/24
- Accipiter
5 months 4 weeks ago #346112
by Accipiter
I went to the network manager and tried to input 10.10.10.100/24 and it wouldn't accept the input?? Is there another way to set the host address?
- Accipiter
5 months 4 weeks ago #346113
by Accipiter
I then went to /etc/hosts and changed the local host to 10.10.10.100/24 which it accepted, then went to ping 10.10.10.10 and got the so far standard response 5 packets transmitted, 0 received
5 months 4 weeks ago #346114
local host should always be 127.0.0.1/8
Don't change that.
You either need to figure out the issue with the setting up a static IP address
with the network manager or edit the interfaces file as described in the
hm2_eth manual page.
googling debian setup static ip address
will give some more options.
Don't change that.
- Accipiter
5 months 4 weeks ago #346121
by Accipiter
Thank you. Will try to pursue your suggestions tomorrow.
Time to create page: 0.238 seconds
