MDI Command Error
- Insomniac
01 May 2026 14:52 #346082
by Insomniac
MDI Command Error was created by Insomniac
Hello.
Recently I ran into an issue with adding in a z probe for automatic tool touch off for a newly built CNC using a mesa 7i96s. After running I get an error "halui.mdi-command-00 does not exist". I have attached my config files. The only line in my postgui file is as follows (so I dont have to attach it)
net ztouch halui.mdi-command-00 <= pyvcp.ztouch
Any help would be greatly appreciated. Thank you!
-Nick
-Nick
Attachment not found
- grandixximo
- Thank you received: 413
02 May 2026 05:28 - 02 May 2026 05:29 #346095
by grandixximo
Replied by grandixximo on topic MDI Command Error
there is no attached file, make sure you have something like this in your INI
[HAL]
HALUI = halui
[HALUI]
MDI_COMMAND = G53 G0 Z-165
also you cannot use the normal hal file, you must put
in the hal file that loads after the UI, I think postgui.hal usually, depends on the UI
[HAL]
HALUI = halui
[HALUI]
Last edit: 02 May 2026 05:29 by grandixximo.
- Insomniac
04 May 2026 13:07 #346160
by Insomniac
Replied by Insomniac on topic MDI Command Error
Sorry for the mistake I have attached my files here.
I do have that line in the post gui file. I also have those other lines you mentioned. Thank you for your help!
- grandixximo
04 May 2026 22:52 - 04 May 2026 23:07 #346166
by grandixximo
You have two [HALUI] section one of which is empty, that could be the issue? what linuxcnc version are you using? I think only recently this has been fixed and properly supported, new parser landed on 11th of April, unless you are using incredibly recent version, your INI with double sections is not well supported
Last edit: 04 May 2026 23:07 by grandixximo.
- Insomniac
05 May 2026 10:25 #346174
by Insomniac
Thank you that fixed that issue. Now I have an error "custom_postgui.hal pin pyvcp.ztouch does not exist". Im wondering if its not loading the file. z_touch.ngc and ztouch.xml are in my subroutines folder. I have attached them here.
- Insomniac
05 May 2026 11:18 #346178
by Insomniac
Just figured it out. I had a file called custompyvcp it was looking into for the ztouch code. Whoops. Thank you again for your help!
- grandixximo
06 May 2026 01:40 #346197
by grandixximo
Time to create page: 0.502 seconds
