please help five Axis with Vismach simulation and Mesa 7i96S
- Alex
28 May 2026 21:07 #346714
by Alex
please help five Axis with Vismach simulation and Mesa 7i96S was created by Alex
Hello,
I worked with 4 Axis simultan on Mach 3 and Powermill and want now do 5 Axes.
I Have self made machine with 5 Axis and all axes are mooving with linuxcnc with the Mesa 7i96s. I added successfully the 5th axis C to xyza
Now I do not find out, how to configure that i can include the Vismach xyzac Simulation.
Would be wonderfull if you could help me make it running
Thank you
PS: i worked a lot in Powermill with the surface Projection Toolpath and making Surfaces. If I can help, ask me
Thank you
- Thank you received: 4149
28 May 2026 23:57 #346719
Replied by rodw on topic please help five Axis with Vismach simulation and Mesa 7i96S
I have not done this but I think I would start with a 5 axis config from pncconf, editing the axis names as appropropriate if your kinematics is not supported.
I would then make a copy of your desired vismach simulator into its own config folder and edit it to suit your machine dimensions etc.
Then I would cut and paste from the pncconf config into your vismach config so its all connected to your real hardware.
The following user(s) said Thank You: Alex
- Alex
30 May 2026 14:35 #346770
by Alex
Replied by Alex on topic please help five Axis with Vismach simulation and Mesa 7i96S
Thank you, but I have to modify the ini and hal file....?
I tried it with KI, but not working...
- Thank you received: 2176
30 May 2026 17:56 #346777
Replied by Aciera on topic please help five Axis with Vismach simulation and Mesa 7i96S
you will need to connect the joint position hal pin to the respective vismach hal pin.
This can be done in either the INI or a hal file.
For an example see
github.com/LinuxCNC/linuxcnc/blob/master...ilting/xyzac-trt.ini
For an example see
# vismach xyzac-trt-gui items
HALCMD = loadusr -W xyzac-trt-gui
HALCMD = net :table-x joint.0.pos-fb xyzac-trt-gui.table-x
HALCMD = net :saddle-y joint.1.pos-fb xyzac-trt-gui.saddle-y
HALCMD = net :spindle-z joint.2.pos-fb xyzac-trt-gui.spindle-z
HALCMD = net :tilt-a joint.3.pos-fb xyzac-trt-gui.tilt-a
HALCMD = net :rotate-c joint.4.pos-fb xyzac-trt-gui.rotate-cPlease Log in or Create an account to join the conversation.
- SwitchWitch
02 Jun 2026 19:11 #346861
by SwitchWitch
Replied by SwitchWitch on topic please help five Axis with Vismach simulation and Mesa 7i96S
Most important: You have to modify the postprocessor to enable tcp.
With 5 Axis you really want to use tcp.
- Alex
14 Jun 2026 10:25 - 14 Jun 2026 10:26 #347065
by Alex
Now it is running, i made ini and hal with Ki.
When running a toolpath in Vismach simulation it shows perfect but the machine makes strange things.
In fact I have not reaaly a plan what setting i need in Linux for 5 Axis...
Scale is correct
Scale is correct
Last edit: 14 Jun 2026 10:26 by Alex.
14 Jun 2026 13:16 #347069
I'm sorry but you do not provide ANYWHERE near enough information to give further assistance.
- Alex
14 Jun 2026 20:19 #347075
by Alex
Yes, sorry, , Thanks for your aanwer. I m still strugeling to make Vismach going. ....I
is there any description for Vismach 5 Axis for a Linux newbie? I think the AI made mistakes....
Right now I found out my toolpath from Powermill is alredy with RTCP
How can I turm off RTCP in Linixcnc?
15 Jun 2026 06:38 #347078
For basic information on your configuration you need to post your .hal and .ini files without that we are just poking around in the dark.
- Alex
15 Jun 2026 21:45 #347101
by Alex
Noe I have working 5Axis Ini and hal with mesa card and would configure for sim.axis.vismach.5axis.table-rotary-tilting.....
.thank you
.thank you
Time to create page: 0.212 seconds
