New builder hardware suggestions
4 months 1 week ago - 4 months 1 week ago #347176 by dbtayl
FWIW there's a balance between "cheap" and "not banging your head against the wall". Totally get not wanting to spend a ton on a first project before you even know if you'll stick with it, but going TOO cheap can be a self-fulfilling prophecy where the cheap parts make the build and end result miserable.
Where I 100% would NOT cut corners is the power supply for the steppers. Get a good one, ideally transformer-based (not DCDC/switch-mode). Steppers decelerating dump energy back into the PSU and can cause voltage spikes, especially with a DCDC supply with relatively small output caps (the transformer-based supplies already have large capacitors to keep the output relatively stable, so have fewer problems with this). If you do use a switch-mode supply, put a BIG capacitor on it, with a high voltage rating. I think I put a... 1000 uF/250V capacitor on mine after blowing up a driver board and a few "unkillable" GeckoDrive stepper drives. No issues after that.
Spending an extra $50 or something on a good PSU can save you hundreds in other killed electronics (not to mention time and sanity).
If absolutely nothing else, not getting the cheapest of the cheap-cheap no-name supplies is probably a good idea, just from a fire hazard perspective.
Last edit: 4 months 1 week ago by dbtayl.
The following user(s) said Thank You: stoobydale
4 months 1 week ago #347184 by rodw
Wow that just got expensive. This is a portable table, the cut dimensions are adjustable at the design stage and I am probably going to make mine 1000x800. The designer suggested a Nema 23 stepper kit with DM542 drivers and a Mach 3 controller from Aliexpress at about $235. I was hoping to use something like this probably with just a different break out board. Is this not possible? This is for hobby use and I am in QLD Australia if that makes any difference. This is also my first build, hopefully learn something and able to modify or make a MK2 at some stage.
I'm also  in Queensland also (Brisbane). You can find my email address on my @MrRodW YouTube channel. You can use a parallel port breakout board.I bought 2 off Amazon for $20. I might have a THCAD which you can use with the encoder component to read torch voltage for THC. If you went with Mach3, you'd probably need to get a Proma THC or similar so it will get expensive quick too. The DM542's should be fine. Very hard to kill. Geckos are way overrated.
Time to create page: 0.131 seconds
