Cannot get out of Estop
23 Jun 2026 16:34 #347287 by galmiklos
Cannot get out of Estop was created by galmiklos
I have a PrintNC machine with a Flexi-HAL board, and installed the customized Expatria LinuxCNC image (github.com/Expatria-Technologies/Flexi-Pi) on a Pi5, then upgraded LinuxCNC to 2.9.8. It all works fine.
I have the Pi5 with an SSD as well as an SD card, so I can kind of multiboot, and the above mentioned setup is on the SSD. I wanted to move from bookworm to trixie, so imaged the SD card with the latest trixie based LinuxCNC image (github.com/LinuxCNC/linuxcnc/releases/do...9.8_arm64_trixie.deb), and copied all the linuxcnc configuration over from the SSD.
LinuxCNC starts with the same configuration, but I cannot get out of ESTOP. I click the big red ESTOP button (using qtdragon_hd), but nothing happens.
Any advise what I can look at?
Thank you in advance!
23 Jun 2026 16:43 #347288 by tommylight
Replied by tommylight on topic Cannot get out of Estop
Does the machine have a physical e-stop?
What comms between RPI and control board?
23 Jun 2026 18:53 #347293 by galmiklos
Replied by galmiklos on topic Cannot get out of Estop
Yes, there is an ESTOP input on the board, but it is not triggered.
The communication between the RPi5 and the board is SPI. The firmware flashed is a customized version of remora-spi, tailored for the Flexi-HAL board by Expatria (github.com/Expatria-Technologies/remora-flexi-hal).
I don't think there is anything is wrong with the board. As I said, I have multiboot set up with an SSD and an SD card, and I have the customized linuxcnc image on the SSD from Expatria (github.com/Expatria-Technologies/Flexi-Pi). If I boot that, everything works.
My best guess is that it is the communication between the board and the Pi through SPI that isn't working for some reason.
23 Jun 2026 21:49 - 23 Jun 2026 21:51 #347295 by galmiklos
Since I had the flexi-pi image on the SSD, I booted it, started linuxcnc in debug mode and saved the output.
I then booted the new LinuxCNC image from, the SD card, and did the same. Started linuxcnc in debug mode and saved the output.
Since the SSD is always connected, I mounted it, and so I could compare the debug output. The only difference was these lines.
DEBUG: Initialising RP1 library: rt_rp1lib_init
DEBUG: Base address:  1f00000000, size: 400000, mapped at address: 0x7ffeecb60000
DEBUG: rp1spi_init(), SPI0
DEBUG: SPI0 Base address:       50000, mapped at address: 0x7ffeecbb0000
DEBUG: dws->ver = 3430322a
DEBUG: Synopsys DWC APB SSI v4.02
DEBUG: Detected FIFO size: 64 bytes
DEBUG: Detected 32-bits max data frame size
DEBUG: Pin: MOSI -> GPIO Number: 10, FSEL Number: 0
DEBUG: Pin: MISO -> GPIO Number: 9, FSEL Number: 0
DEBUG: Pin: SCLK -> GPIO Number: 11, FSEL Number: 0
DEBUG: Pin: CS   -> GPIO Number: 8, FSEL Number: 0
DEBUG: clk_div = 10
DEBUG: BAUDR = 20000000 hz
I don't know where to get this ;library from, I thought it would be part of the "flexi" component that comes withe flexi-pi image.
Last edit: 23 Jun 2026 21:51 by galmiklos.
24 Jun 2026 09:14 - 24 Jun 2026 09:21 #347305 by galmiklos
I found the culprit! :-)
Apparently, the customized component that handles the SPI communication with the customized remora-spi firmware is not compatible with trixie.
This is the part in the code that breaks it.
int rt_peripheral_init(void)
    int  memfd;
    FILE *fp;
    // assume were only running on >RPi3
    if ((fp = fopen("/proc/device-tree/soc/ranges" , "rb")))
The soc ranges path is different in trixie.
root@raspberrypi:~# hd /proc/device-tree/soc\@107c000000/ranges
00000000  00 00 00 00 00 00 00 10  00 00 00 00 80 00 00 00  |................|
00000010
I modified the component so, that when the path does not exist, I just consider it as a Raspberry Pi 5 with RP1 chip, and now it works! :-)
    else
        DEBUG_PRINT("Raspberry Pi 5, using RP1 driver\n\n");
        rp1 = true;
I know it's just a quick and dirty workaround, but works for me.
Last edit: 24 Jun 2026 09:21 by galmiklos.
24 Jun 2026 09:48 #347308 by tommylight
Thank you for reporting back.
