G38.2 Weird behaviour
03 Jul 2026 20:33 #347492 by andypugh
Replied by andypugh on topic G38.2 Weird behaviour
There is a new release (2.9.10) that reverts this change.
Unfortunately it's not yet available from our repository as I am having trouble with the archive signing key.
However, you can manually install .deb files from here:
github.com/LinuxCNC/linuxcnc/releases/tag/v2.9.10
The following user(s) said Thank You: tommylight, MaHa
06 Jul 2026 15:39 #347559 by Odiug
Replied by Odiug on topic G38.2 Weird behaviour
I see you have withdrawn 2.9.9.
I tried an "apt-get clean; apt-get update; apt-get upgrade", but still get:
E: Failed to fetch www.linuxcnc.org/dists/bookworm/2.9-uspa...pace_2.9.9_amd64.deb 404 Not Found [IP: 69.163.143.134 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Is this related or an issue on my side?
07 Jul 2026 06:08 #347573 by Aciera
Replied by Aciera on topic G38.2 Weird behaviour
'2.9.9_amd64.deb ' cannot be fetched because it has been removed. If you want to update to 2.9.10 use the link to the deb file posted by andypugh
Time to create page: 0.117 seconds
