C axis milling cycles. Anyone written any?
09 Jul 2026 23:17 #347646 by M4MazakUser
C axis milling cycles. Anyone written any? was created by M4MazakUser
Setting up a c axis with a turret milling spindle,  has anyone written any subroutines/cycles to make milling square/hex/oct/triangle shapes.
such a cycle would have to take into account tool radius, distance from zero,width of shape (in respect to tool width).
If not , looks like i have a bit of maths in front of me...
- I wrote a set of cycles 12+ years ago and uploaded them here that were for quick program creation (they calced tool change position etc for multiple tools) after changing jobs over the years etc, I looked it up and it seems that once uploaded the forum had corrupted them, I downloaded the mess and got them to work for the current machine i use. I probably should tidy them up and upload them again!.
10 Jul 2026 10:27 #347656 by spumco
Replied by spumco on topic C axis milling cycles. Anyone written any?
I've not seen any macros or subroutines ever posted for C-axis milling.
There have been a couple of polar interpolation posts, but nothing I'd call 'universal.'
You might look at this:
forum.linuxcnc.org/show-your-stuff/53476...rical-mapping#308478
Note that Fusion360 appears to have (somewhat recently) added a feature for polar interpolation mode.  Rather than using a machine's built-in polar interpolation F360 outputs XC moves directly instead of XY.
I've not tried it yet, but worth a look.
13 Jul 2026 00:13 - 13 Jul 2026 01:10 #347723 by M4MazakUser
Replied by M4MazakUser on topic C axis milling cycles. Anyone written any?
Yeah, not really that easy though, I'm really going to have to write one so it's more like an easy to write cycle on the machine. Like a conversational control.
Last edit: 13 Jul 2026 01:10 by M4MazakUser. Reason: Clearer description
13 Jul 2026 13:36 #347740 by spumco
An alternative to consider would be using polar interpolation combined with a 'standard' set of macros for XY-type milling.
As I mentioned earlier, polar interpolation is not in main-line LCNC but there is a working configuration available on the forums:
forum.linuxcnc.org/10-advanced-configura...oling?start=0#225787
Nojo's implementation works, but I think the hurdle for anyone else to use it is that Nojo hard-coded the live tool offsets to match his particular machine.  I'd think some editing of the comp would be required to make it a universal component/scheme.  (i.e. use the currently loaded tool offset, not a fixed offset)
If you found an existing 'conversational' configuration/GUI you liked, polar interpolation should permit programming using that conversational system.
However, it's understandable if you're not interested in falling down the comp file development rabbit-hole and just want some working macros.
