Unable to Jog When HAL_ToggleBtn Active
- scsmith1451
- Thank you received: 3
13 Jul 2026 12:54 #347745
by scsmith1451
Unable to Jog When HAL_ToggleBtn Active was created by scsmith1451
I have a standalone gladevcp panel that has a HAL_ToggleBtn configured and hooked up. The button activates an output that turns on my X/Y laser crosshair for locating program X/Y start. When the button is activated, the laser turns on as expected, however, I cannot jog while the button is active. As soon as I deactivate the toggle button, I can jog.
I know it is not related to the laser itself as I have an override switch on my machine that allows me to turn the laser on. When the switch is on, I can jog just fine.
This issue occurs with both AXIS and GMOCCAPY interfaces, so it is something in the bowels of LCNC.
Anyone have any insight on this issue or a workaround?
01 Aug 2026 06:54 #348336
Replied by andypugh on topic Unable to Jog When HAL_ToggleBtn Active
Open a halmeter and see what the mode flags show:
linuxcnc.org/docs/stable/html/gui/halui.html#_mode
mode.is-manual needs to be true for jogging to work, it seems possible that something is changing mode.
Are you keyboard jogging, or using handwheels? It might just be a UI focus problem, with the key presses being "captured" by the button itself.
But check the mode first.
- scsmith1451
11 Aug 2026 08:15 #348651
by scsmith1451
Replied by scsmith1451 on topic Unable to Jog When HAL_ToggleBtn Active
I'm using the physical keyboard keys to control jogging.
Checking halui.mode.is-manual = FALSE. I attempted to set it to TRUE but halshow reported that the parameter is not writable.
Is there a way to force this pin to be high?
Regards,
Regards,
- Thank you received: 4154
11 Aug 2026 14:51 #348658
Replied by rodw on topic Unable to Jog When HAL_ToggleBtn Active
halui.mode.teleop bit inpin for requesting coordinated jog mode
The following user(s) said Thank You: scsmith1451
Time to create page: 0.093 seconds
