Getting Trixie to play nice
15 Jul 2026 07:57 #347781 by aaron
Getting Trixie to play nice was created by aaron
HI
I have just updated the hardware and the software running a 4-axis router to LCNC on Trixie. However, I am unable to stop the screen from going blank and, more annoyingly, when I run a program, the machine randomly stops moving partway through the job, and I have to press the stop button on the screen, click on the last line of code it ran, and then click 'run from here'.  When this happens, the screen is still active, but I am wondering if these two issues are related.
Can anybody offer a solution?
Thanks Everybody
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
15 Jul 2026 11:17 #347789 by rodw
Replied by rodw on topic Getting Trixie to play nice
You should be able to disable the screen saver under power settings and/or Display but it has got more difficult
In my ISO, I had to go to great lengths to force this modifying xfce config files but its not in a format to share as a script as its in the live build environment
15 Jul 2026 12:55 #347791 by tuxcnc
Replied by tuxcnc on topic Getting Trixie to play nice
In Trixie you have to disable power manager and screensaver in startup options (Main menu -> settings -> session and startup) and add the line bellow to ~/.bashrc
xset dpms 0 0 0 s off
The following user(s) said Thank You: reboots, NWE
Time to create page: 0.099 seconds
