Gantry oxyfuel / plasma type machine from scratch
2 months 2 weeks ago #348665 by saxa
I was wondering if I should buy direclty the 7i95T as it has all needed i/o and encoder feedbacks for up to 6 axis.
What you suggest ?
Yes, that would be better, but finding it sometimes not easy,
With Mesa, you can add inputs and outputs and PWM and encoder feedback as you see fit:
-more IO = 7i84 or 7i70 or 7i71 or 7i72
-more encoders = 7i85 or 7i85S (not the same, only half the same)
-more PWm for +-10V servos = 7i83
Many thanks, will take a closer look to those.
2 months 2 weeks ago #348695 by rodw
What you exactly mean by "downdraft zones" ? I have not yet build the table where the workpiece will sit on.
But the gantry is already existing and here are some pictures of when I received it.
Some large commercial tables have a central exhaust duct down the side or up the centre and as the torch passes into a zone, a gate opens and the others close (usually by pneumatics) so the draft is centralised in that particular cutting zone. It is possible to track the torch position and activate the relevant zone with LinuxCNC. The dust is usually filtered and the exchaust ducted outside of the building. I did write a component that did this for another user which triggered a bank of air solenoids.
The following user(s) said Thank You: saxa
2 months 2 weeks ago #348740 by saxa
Rod, you catched me, thanks for this heads up. I have not even thought about that problem of exhaust gases and
pollution stuff. I was thinking to make a water based table under the torch, but this solves just partly this
problem of gases. We have a luck of being in a country where its hot the whole year so everything is open and ventilated, but that does not mean I dont need it.
Time to create page: 0.079 seconds
