mesa card 5i25 not being seen by mesaflash after update
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
24 Jul 2026 13:02 #348029 by bevins
Hi guys,
I have updated from 2.9 to the latest linuxcnc. It is running but two main issues one is the onboard 7i77 enc0 does not exist when it did before and mesaflash does not see the 5i25.
I assume the enc is related to the 5i25 and the 7i77 has old firmware message.
My question is Is it possible that the new mesaflash not see an old 5i25 card? and if not how to we get it updated?
Linuxcnc runs and see the 5i25 and everything seems to work except no enc0.
Thanks,
Bob
Bob
  • bevins
  • Platinum Member
  • Platinum Member
24 Jul 2026 13:32 #348030 by bevins
The motherboard is using pcie to pci bridge. I am wondering if this is the issue. Mesaflash doesnt like i but linuxcnc doesnt mind. Just a thought.
24 Jul 2026 14:08 #348031 by PCW
What does
lspci -v
report?
Is this a new motherboard?
I have seen this issue before where PCI devices are found but not enabled
(LinuxCNC enables disabled PCI devices but mesaflash does not)
  • bevins
  • Platinum Member
  • Platinum Member
24 Jul 2026 14:46 #348033 by bevins
Thats what is exactly happening. So my options are get a new motherboard or put the 5i25 back in the old pc, and update the firmware in it. Also need to update the 7i77 firmware.
Will the 2.9 linuxcnc pc able to update the latest firmwares or is that verson of mesaflash too old?
24 Jul 2026 14:52 #348034 by PCW
I don't think mesaflash has changed but rather your PC or BIOS
Did you just update to LinuxCNC 2.9 or did you change other hardware at the same time?
  • bevins
  • Platinum Member
  • Platinum Member
24 Jul 2026 15:03 - 24 Jul 2026 15:05 #348036 by bevins
updated the old PC to a new one and linux and linuxcnc to the latest.
Last edit: 24 Jul 2026 15:05 by bevins.
  • bevins
  • Platinum Member
  • Platinum Member
24 Jul 2026 15:07 - 24 Jul 2026 15:09 #348037 by bevins
wait, if Linuxcnc enables it, then can I start linuxcnc and then run mesaflash? we'll try it.
Last edit: 24 Jul 2026 15:09 by bevins.
