After moving, cannot connect to my second linuxcnc mesa 7i96s
3 months 3 days ago - 3 months 3 days ago #348164 by ffffrf
I am really struggling to figure out what the issue is here and am looking for some help. Prior to moving states, I set up linuxcnc with my mill and it was working fine, I then purchased a lathe and another mesa board (both are 7i96s) and attempted to set it up and I was unable to do so, it took a lot of debugging with AI but eventually I found a way for both boards to work even though both were set at 10.10.10.10. However, now after moving, I have set everything back up, and my mill board does not communicate with my computer at all and I don't remember how to solve the issue. Here is what I know so far:
1. Originally, both boards were using EEPROM jumpers and 10.10.10.10 (and my HAL files reflect those IP addresses)
2. The default IP address has never worked for me for either board
3. Currently, my lathe board works correctly, when I plug it into my computer everything connects up right away and works as expected, it is also the last board I used prior to the move (meaning my lathe was the last machine I was using)
4. I am unable to ping the mill board, mesa flash does not recognize any 7i96s connected when the mill is plugged in, because of this, I cant change the IP address
5. the LED lights / sequences are identical in both boards on powering up
6. I tried upgrading linuxcnc and updating my packages and that did not help
7. IF I unplug all of the ports on my lathe board and move it over to my mill, the mill does work and linuxcnc connects
It feels like there is an IP address conflict or something else going on where it's expecting the lathe board because that's what was last used. I recall having this exact same issue when I first purchased the lathe but for the life of me I cant remember how I actually fixed it. I do not think the actual mesa board is broken in any way.
Does anyone have any big picture suggestions on what I can do for further debugging in terminal?
Last edit: 3 months 3 days ago by ffffrf.
3 months 3 days ago #348165 by rodw
Are you using seperate NIC's for each Mesa board?
3 months 3 days ago #348166 by ffffrf
I am using a single ethernet port on my computer where only one board is attached at any one given time (so I unplug one board and replug the second board)
3 months 3 days ago - 3 months 3 days ago #348169 by rhscdn
' IF I unplug all of the ports on my lathe board and move it over to my mill, the mill does work and linuxcnc connects'
I assume you are using the same known working Ethernet cable in all cases so you can rule that out. Assuming you have the problematic 7i96s on your bench with only it's ethernet and good 5v power connected, I would probably cycle the power and the IP related jumpers (W4 and W5?) and see if you can get it to ping on any address. Beyond this, you can try using mesaflash with the card type and AUTO to try and scan to locate the card. I've had the EEPROM corrupt on my card once and needed to reflash with 'mesaflash --device 7I96s --write <path_to_firmware>.bit' to get communication working again.
Last edit: 3 months 3 days ago by rhscdn.
3 months 3 days ago #348170 by tommylight
The following user(s) said Thank You: rhscdn
Time to create page: 0.315 seconds
