RS485 + Absolute Encoder for Homing a 4th Axis?
- GeckoWorks
- Thank you received: 8
31 Jul 2026 04:20 #348259
by GeckoWorks
RS485 + Absolute Encoder for Homing a 4th Axis? was created by GeckoWorks
I got my hands on a used 4th axis but need to put in a new servo which is fine. I have a Delta B3 750w servo and drive with absolute, multi turn encoders on the way (used, too).
The machine will have Mesa cards but given that the 4th axis supposedly has no homing sensor (still waiting for it to arrive), I was hoping to be able to home it to the absolute encoder of the servo.
Would it be possible and not too difficult to use the RS485 from the drive into the host PC (with a USB adapter) to do the homing? AI seems to think so but I don't know how well versed it actually is in LCNC. It did however say that latency shouldn't really be an issue given that this is homing routine done at the start and not something that happens during actual machining.
If this is not doable or takes a lot of trickery, I will try to put in a small hall effect sensor and home to that + Z-pulse. But would be nice if I didn't need to do that.
- Thank you received: 1480
31 Jul 2026 11:02 #348279
Replied by Todd Zuercher on topic RS485 + Absolute Encoder for Homing a 4th Axis?
If the drive and motors have absolute encoders and if you are not having encoder feedback to Linuxcnc, you may be able to program the drive to move to the "home" position when Linuxcnc sends it a home command. Then have send a homed signal to Linuxcnc which Linuxcnc could see as the home switch.
Linuxcnc also supports absolute encoders and if the absolute encoder position is being fed back to Linuxcnc, then homing is not necessary at all.
The following user(s) said Thank You: GeckoWorks
- GeckoWorks
31 Jul 2026 14:09 #348291
by GeckoWorks
Replied by GeckoWorks on topic RS485 + Absolute Encoder for Homing a 4th Axis?
The B3 drives can definitely home in the drive with a switch + z-pulse just like you said: you send a home command from a DO on the Mesa and the drive will return a signal back once done.
But it's possible it can also home internally using only the absolute encoder value plus some gearing table for the Harmonic Drive. I didnt even think of that but will scour the manual:)
That would be the cleanest solution, I think.
Time to create page: 0.179 seconds
