Ver 10 NEW install
01 Aug 2026 14:10 #348344 by 5280
Ver 10 NEW install was created by 5280
Good Day CnC's
I am a "TOTAL" new bee to Linux and to LinuxCnC trying to get the new Ver. 10 to run with the help of AI and maybe 5-6 hours installing on my  Zorin 18.1 Linux computer.
I managed to get it installed only to get an terminating error on opening the program it says to create a report file which i did but can not find the report and don't know how to send it to someone if i did find it. so I seem to need some help if some one can provide some guidance
here is a cut and paste of the error. it will not be hooked to any machine at this time. Just would like to get the program to run for right now
Tks if anyone would like to tackle this. if not I'll understand.
5280 (ken)
Print file information:
RUN_IN_PLACE=yes
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/home/ken/linuxcnc-dev/bin
LINUXCNC_TCL_DIR=/home/ken/linuxcnc-dev/tcl
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/home/ken/linuxcnc-dev/rtlib
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/home/ken/linuxcnc-dev/src/objects
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.10.0~pre1
Machine configuration directory is '/home/ken/linuxcnc-dev/configs/by_machine/cooltool'
Machine configuration file is 'Basic540_3axes.ini'
INIFILE=/home/ken/linuxcnc-dev/configs/by_machine/cooltool/Basic540_3axes.ini
VERSION=1.1
PARAMETER_FILE=stepper.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
HALBRIDGE=
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins
Starting LinuxCNC...
Can't execute server program linuxcncsvr
Debug file information:
Stopping realtime threads
Unloading hal components
rtapi_app: exit received while not running
02 Aug 2026 00:27 #348360 by rodw
Replied by rodw on topic Ver 10 NEW install
please share your Hal and ini files. I think you have added something that's not necessary.
Can you run an axis sim?
02 Aug 2026 00:39 #348362 by tommylight
Replied by tommylight on topic Ver 10 NEW install
Test using one of the included sim configs, like Axis_mm.
The cooltool one you tested fails here also, but with a different error.
02 Aug 2026 01:51 - 02 Aug 2026 01:52 #348363 by Aciera
Replied by Aciera on topic Ver 10 NEW install
Using the unstable pre release is probably not the easiest entry point for a new user. Unless there is a compelling reason for this  I would strongly suggest to use the stable 2.9.10 instead.
'$ git checkout 2.9' and rebuild
Last edit: 02 Aug 2026 01:52 by Aciera.
03 Aug 2026 14:04 #348409 by 5280
Replied by 5280 on topic Ver 10 NEW install
Thanks Guys fro trying.
"the realization is " I am "OVER MY HEAD and sinking FAST
Linux / LinuxCnC.
toooo many choices and tooo many variables
in OVER MY HEAD
But thanks for trying
03 Aug 2026 14:26 #348411 by Aciera
That is why there is a ready made ISO to get you started:
Download and install 'Debian 13 Trixie PREEMPT-RT ISO'
linuxcnc.org/downloads/
The following user(s) said Thank You: rodw, 5280
06 Aug 2026 14:36 #348494 by 5280
Thank you for the reply (link to the Debian 13 install link after building a USB boot install flash drive and doing the install on the (older Dell laptop 8 gig memory)thee install goes fine till the password section which i have tried any number of password from 4 letters to 20 letters / numbers .? nothing get me past the enter login on the reboot . Every thing looks fine on the setup "but" ? I guess I am not to have this I have never understand why since I am the only person "WHY " I need a password" and the only person who will use this people have gotten crazy with the requiring passwords
Thanks for the help
06 Aug 2026 15:19 #348495 by 5280
Sorry about Pxxx/Moning about passwords I am leaving M.S. because of how they handle the passwords. I have been building boxes since Aug of 1977 (Almost 50 years) and over 100 boxes's
why cant they just have a check box do you need a password yes / no and leave it at that
1 frustrated old man
Ken (5280)
06 Aug 2026 16:44 #348497 by Todd Zuercher
Replied by Todd Zuercher on topic Ver 10 NEW install
It is possible to set up a linux system with no passwords, but it isn't completely simple or recommended (especially on systems with any internet exposure.)
First you can do away with a root password, by leaving that blank when installing. The user password is required while installing, but you can configure Linux to boot directly to the user interface by enabling automatic login, and the system will start without needing to input a password.
If you configured the system without a root password, the installer will have given sudo privileges to the user, and will promp for a password when a sudo command is input at the terminal.
With automatic login and sudo privileges for the user, you would only need to enter your password to perform administrative tasks that probably should be password protected. Otherwise you shouldn't normally need to user your password.
There are ways to even remove the requirement for a password for sudo tasks, but I've never tried and would have to google instructions how to do it. (not to mention that it's generally probably not a good idea.)
06 Aug 2026 17:03 #348498 by 5280
Tks for the info But I stick to GIVE THE USER THE CHOICE right off the bat....! an force me to "DIG" for that info to have to disable. at a later date
I under stand with the internet the way it is.? "BUT" give me the "choice"
I understand this will never HAPPEN but had to get my 2 cents worth in.!
the old timer
Time to create page: 0.270 seconds
