G Code viewer
- Routerworks
- Thank you received: 14
03 Aug 2026 12:58 #348420
by Routerworks
G Code viewer was created by Routerworks
I have tried a few online g code viewers. None of them seem great. Actually the best and most accurate one is the one that comes with Linuxcnc. However I would like to view my g code on my windows computer where my CAD and other software are locaated. I have been using NC Viewer but it won't slow down g83 g code or show the pecking steps.
Any suggestions?
Thanks in advance.
Any suggestions?
Thanks in advance.
- tuxcnc
- Thank you received: 58
03 Aug 2026 13:09 #348422
by tuxcnc
Replied by tuxcnc on topic G Code viewer
camotics.org/gcode.htmlAny suggestions?
- Routerworks
03 Aug 2026 14:11 #348424
by Routerworks
Replied by Routerworks on topic G Code viewer
Many thanks. I'll give it a try.
- zz912
- Thank you received: 98
10 Aug 2026 09:34 #348630
by zz912
Replied by zz912 on topic G Code viewer
One option is to run LinuxCNC in a virtual machine on your Windows PC. You can use the simulator (SIM) configuration, so you don't need any actual CNC hardware. This gives you the same G-code preview as in LinuxCNC, including things like G83 peck drilling and the individual pecking steps.
Basically just run LinuxCNC in a VM in simulation mode.
- Routerworks
11 Aug 2026 07:46 #348647
by Routerworks
Thanks, I'll give it a try.
