Industrielle Linux CNC 5achs Fräsmaschine
1 month 3 weeks ago #349348 by tuxcnc
In my opinion, Ethercat is a great solution for small machines that can use integrated drives.
I have mills where the individual axes are connected to the rest of the machine via a one patch cord and one power cord, and things like homing limit switches  or other sensors are connected locally to additional drive inputs.
Such a machine is simple to wire and, in my opinion, more reliable.
However, if all the control is to be located in one cabinet and long and multi-core cables are to be run, Ethercat loses its advantages for now. It's just expensive and difficult to set up, and what's best about it becomes secondary...
1 month 3 weeks ago #349368 by rodw
Nonsense. ethercat drives whole factories. The advantages of ethercat remain regardless of the size of the machine. Ethercat should be a more efficient protocol than mesa hm2 so it should have more efficient bandwidth utilisation. Linuxcnc won't care if you use mesa or ethercat
1 month 3 weeks ago #349380 by tuxcnc
We don't talk about what is used in industry and why. We are talking about using Ethercat in a machine controlled by LinuxCNC. And here we have factors such as the availability and quality of documentation, sample configurations, or tools, and here Ethercat loses to Mesa. Therefore, I believe that unless there are compelling arguments for Ethercat, it is better to use Mesa.
"Ethercat is faster" is not a valid argument, because anything that is faster than the required minimum will be sufficient.
1 month 3 weeks ago #349390 by tommylight
"Ethercat is faster" is not a valid argument,...
He did not say "faster", he said more efficient, and even that does not seem correct to me from what i read around here, no experience with ethercat yet except rare services of machines using them.
I am intentionally refusing to use ethercat until something is done to have proper feedback, so far it does not work or it does work with big delays.
But, i would really like to have the redundancy it may offer, for now only in showrooms.
ASUS ROG Crosshair VIII Impact - AMD X570
1 month 3 weeks ago #349392 by tuxcnc
I don't have much experience with Ethercat.
I simply had a milling machine frame without drives and I was curious if I could handle it.
I ordered integrated Lichuan drives and managed to configure the machine.
It wasn't easy, but the first time never is...
Since it worked really nicely, I decided to convert a second milling machine, basically identical, only slightly larger, so apart from a few numbers in the ini file, it should work with the same configuration.
I bought identical drives, connected them identically, ran LinuxCNC with the configuration from the first one and basically everything worked, except the motors did not rotate...
I wasted a lot of time before it turned out that I had to write the same thing in the xml file, only in a different order.
The manufacturer probably improved something, and that's how it ended.
Since then, I have been very cautious about recommending Ethercat to someone who has never used it before.
I really like Ethercat, but for now there are too many problems with it.
It will probably get better with time.
1 month 3 weeks ago #349417 by MisterXmin
Ok, so for the first test I will use a mesa card, since I don't want to mess with the original motor drives. However if we decide to use Linux CNC multiple machines may be converted, therefore the hassle implementing ethercat is valid. Am I right when looking for a PC that has a Intel nic and 8th gen i5? Is Linux CNC able to do collision detection of the machine gcode?
Time to create page: 0.092 seconds
