Those will cause the "error finishing read", not latency error, so for now do not bother with it, see here:The biggest issue is not using the dkms drivers with realtek NIC's. Try to always use Intel NIC's.
Usually the call to OpenGL subsystem used by Gremlin will do this, more often with NVIDIA graphic cards and some integrated Intel ones..... or it is called at the wrong moment (LinuxCNC starts and maybe something jams, but only then and only once).
