Clock and calculator Qs
12 Sep 2026 20:40 #349604 by Cayenne
Clock and calculator Qs was created by Cayenne
I'm on 2.7.15 How in the world do you make the desktop clock read bios clock and keep correct time? i'm a linux newb
Did this version really ship with NO calculator???
12 Sep 2026 23:13 #349606 by dbtayl
Replied by dbtayl on topic Clock and calculator Qs
Are you talking clock drift, always resetting to (eg) 00:00, a timezone offset, or something else? If it's drift, that's normal... clocks drift, some are shockingly bad. A lot of times you don't see it because OS's are configured to sync to the Internet regularly. You can check the time in the BIOS to verify that. If you don't have an internet connection on the machine, you're probably stuck with the drift/manually adjusting it occasionally.
Always resetting to 00:00 is probably a dead battery, timezone offset is likely misconfiguration or (if you're dual-booting) Windows and Linux fighting over whether BIOS time is localtime or UTC.
No calculator... pretty sure it has Python installed, which IMO is the best calculator around.
The following user(s) said Thank You: NWE
13 Sep 2026 03:02 #349607 by rodw
Replied by rodw on topic Clock and calculator Qs
sudo apt install galculator
13 Sep 2026 09:51 #349611 by Cayenne
Replied by Cayenne on topic Clock and calculator Qs
cayenne@LinuxCNC:~$ sudo apt install galculator
[sudo] password for cayenne:
sudo: apt: command not found
This worked
sudo apt-get install galculator
But returned nothing but a bunch of 404s
I'm on ver 2.7.15 and everything I try and install including with the synapptic thing it all returns 404s
  • Moderator
  • Moderator
13 Sep 2026 10:02 #349613 by tommylight
Replied by tommylight on topic Clock and calculator Qs
sudo apt-get update
before
sudo apt-get install xxxxxxxxx
Time to create page: 0.230 seconds
