LCNC and Stepspeed?
19 Oct 2026 06:29 #350330 by Holzwurm56
LCNC and Stepspeed? was created by Holzwurm56
Hello,
When using a parallel port, entering the jitter value in Stepconf results in the calculation of the maximum step rate. Does this figure—for example, 33333 Hz—apply to each axis individually, or to all axes combined?
Best regards,
Hans
19 Oct 2026 13:22 #350341 by tommylight
Replied by tommylight on topic LCNC and Stepspeed?
Hello,
For each pin, parallel port so all pins can be controlled in parallel or at the same time.
19 Oct 2026 15:32 #350346 by Holzwurm56
Replied by Holzwurm56 on topic LCNC and Stepspeed?
Many thanks for your response.
Time to create page: 0.563 seconds
