Help identifying a CM5-based LinuxCNC controller
  • tietouwa
  • tietouwa's Avatar Topic Author
  • New Member
  • New Member
27 Oct 2026 02:01 #350476 by tietouwa
Hi everyone,
I came across a piece of CNC controller hardware running LinuxCNC. Does anyone recognize this setup or know who makes it?
I checked the system over SSH and found:
- Raspberry Pi Compute Module 5 Rev 1.0
- 2 GB RAM and 16 GB eMMC
- Debian 12 Bookworm
- LinuxCNC 2.9.3
- PREEMPT_RT kernel: 6.6.54-rt39
- CPU configured to run at 1.8 GHz
- Realtek RTL8111/8168 Ethernet controller using the ec_r8169 EtherCAT driver
- EtherCAT master 1.5.2
- WCH USB device (1a86:5537) using a custom ch37x driver, with /dev/ch37x0
- PCF8563 RTC
- Connected touchscreen
The EtherCAT master is detected, but its link is currently down and no slaves are connected.
Does this look like a known commercial controller or a custom carrier board? I would appreciate any information about its manufacturer, model, hardware revision, or available documentation and LinuxCNC configuration files.
Thanks!
15 Nov 2026 12:21 #350730 by andypugh
I have thought for a while that a board with some serially-controlled stepper drivers and a CM5 socket might be a useful product.
If you can see the network config and see a fixed IP of 192.168.1.x (expicitly not 121) or 10.10.10.x then it might hint that there is a Mesa ethernet card attached.
16 Nov 2026 01:25 #350739 by rodw
probably just a broken Ethercat machine. I would try changing the drive to ec_generic as the R8168 driver uses different drivers. In fact I thought the recommendation from iGh was to use the generic driver with a Ethercat deb install.
I would:
check that non-free is included in the sources
sudo apt update
sudo apt install dkms
sudo apt install r8168-dkms
set Ethercat to use ec_generic driver.
Time to create page: 0.207 seconds
