I usually only run the test for a few minutes. I will start it now...running...and leave it there. I've read that page you linked to, thank you. I've decided to monkey with this just a little more and then, if it doesn't get better, scrap this system and move on. I have two or three more PCs I can try loading the Live CD on and see if they work okay. They're older systems and that one Intel board you mentioned is sounding good to me. But I've not given up yet. I just changed some settings in the BIOS trying to resolve the aberrant latency problems and I've got a couple more I'll try later.
As long as I've got you, and tell me if I should post this as a separate topic, which CAM software do you use for creating G code for your plasma table? I'm using Vectric's Cut2D for the router table but I don't think it's going to do well for planning cuts on a plasma table.
Thank you.
--HC
