Can I do speech output via festival
20 Feb 2011 20:23 #7332 by jrsphoto
Just wondering how I could go about having EMC2 output speech when a job starts. Something like, "Job Starting, or "
Job Complete". I would assume I could use festival (linux speech engine)?
-John
20 Feb 2011 21:03 #7335 by BigJohnT
I'm guessing M1xx...
27 Feb 2011 16:19 #7489 by andypugh
As John said, it should be doable with a custom G-code (M100 to M199)
Assuming that you can do what you want through a command line, then just create a bash script linked to a G-code as described here:
linuxcnc.org/docs/html/gcode_main.html#sec:M100-to-M199:
Time to create page: 0.061 seconds
