CNC4PC Electronics with EMC2
- lbaroudi
15 years 8 months ago #7469
by lbaroudi
CNC4PC Electronics with EMC2 was created by lbaroudi
Hi there,
I have purchased the below hardware that is about to be connected to my hand made CNC from buildyourcnc.com/default.aspx
Breakout board : C11G 1996 www.cnc4pc.com/Store/osc/product_info.ph...th=33&products_id=46
Pendant Interface Card for LPT C22: www.cnc4pc.com/Store/osc/product_info.ph...h=40&products_id=159
MPG4 - 6 Axis Pendant: www.cnc4pc.com/Store/osc/product_info.ph...h=40&products_id=162
MPG4 - 6 Axis Pendant C19: www.cnc4pc.com/Store/osc/product_info.ph...h=25&products_id=155
Power Supply: kelinginc.net/KL-350-97.pdf kelinginc.net/KL-350-36.pdf
Motors Drivers: kelinginc.net/KL-4030.pdf
Motors: kelinginc.net/KL23H286-20-8B.pdf
if someone have any diagram connecting Breakout board C11G to Power Supply KL-350-36 and Motor Driver KL-4030and Motor KL23H286-20 and the rest of hardware to EMC and configuration
and how to make test on EMC2 ubunto 10.10 with external 5v power supply please advice for making life easy for me
Labib
Labib
- BigJohnT
- Thank you received: 994
15 years 8 months ago #7485
by BigJohnT
Replied by BigJohnT on topic Re:CNC4PC Electronics with EMC2
Just in case no one has the exact hardware as you and has not taken the time to create a tutorial on assembling it you might start by asking a specific question at some point as you assemble your project. Try to include as much detail about what you have done and what your unsure about when you ask the question.
- lbaroudi
15 years 7 months ago - 15 years 7 months ago #7578
by lbaroudi
Replied by lbaroudi on topic Re:CNC4PC Electronics with EMC2
Last edit: 15 years 7 months ago by lbaroudi.
- Rick G
- Thank you received: 114
15 years 7 months ago #7594
by Rick G
Replied by Rick G on topic Re:CNC4PC Electronics with EMC2
Looks good.
To get things started select
Stepconf
from the cnc menu and run the set up program to get the motors running.
Later you may have to edit the setup for other devices.
A lot can be learned by looking at the sample configs that are included.
Good luck and have fun.
Rick G
Stepconf
Rick G
- Rick G
15 years 7 months ago #7595
by Rick G
Be sure to run the Latency test first to get the numbers for your computer.
If you have not done so be sure to read the docs here especially the getting started guide.
www.linuxcnc.org/content/view/5/5/lang,english/
Rick G
Rick G
- arturod
15 years 7 months ago #7671
by arturod
Replied by arturod on topic Re:CNC4PC Electronics with EMC2
Time to create page: 0.160 seconds
