Latency Results for Real Time Servo Conf.
Servo Thread; Max int (ns) 1010484 max jitter: 12084
Base Thread: Max int (ns) 37964 Max Jitter: 14160
I ran this for 15 minutes and going to leave it running overnight. I'm wanting to know if I'm going to be ok with these numbers running a closed loop realtime servo config? I don't have my servo hardware yet but it's in the mail.
but the trade-off with isolcpus=1 is that user programs only have 1 CPU so will run slower.
12 usec latency is fine for a servo system so a little more latency with snappier user interface
is probably a good tradeoff
If it is a D510MO the latency should be lower... but that is fine for a servo machine using something like a Mesa 5i20 + 7i33 +7i37 type of setup.
It is the D510MO. I just upped the ram timing to 5-5-5-15 and it didn't effect anything. This is also with HT turned off. I'm not to sure if an old SATA HDD would effect anything. I also have a PP Card installed in the PCI slot. I had it their just so the drivers would be installed so if I had to use it on down the road. Tomarrow I'm going to get a 16GB USB 2.0 thumb drive and see how it runs with no HDD. The HDD is so damn slow. It's a 250GB Deskstar. I'm not to sure how to implament the cpu change. It is a duel core and I don't mind dedicating one core just for EMC2 cause this machine is my CNC Machine.
www.linuxcnc.org/component/option,com_ku...0/lang,english/#6955
Servo Thread 1,003,677 Max Jitter 5,432
Base Thread 31,215 Max Jitter 6,255
It's much better.
So for a software generated step machine it might be a good compromise
since that low a latency will allow you to generate quite high step rates via a
parallel port.
On the other hand, for a servo machine even 20 uSec or so of latency
would hardly be noticeable so you might want the better userland responsiveness
instead of minimum jitter in that case
On a side note. I just removed my HDD and am using a USB 2.0 8GB stick. I'm not to sure if it's any faster It feels like it but it actually made my latency a little worse. New scores with fresh install. This is running 3x glxgears, update manager, Several FF windows.
Servo: 1,014,461 Max Jitter: 16459
Base: 42325 Max Jitter: 18576
It's a little strange but I'm also trying to minimize heat and not using a HDD is definitely going to cut down on heat production. Well actually 3x glxgears is kepting both CPU's at 90%+ Load. And the system seems to bring up icons and menus faster than with the old HDD. I think with a little tweaking of Ubuntu I can get his pretty fast and low latency. I'm going to look into using control containers for EMC2. Maybe I can get the best of both worlds.
A few questions. How do I disable disk swap? I don't want to use it with a Memory stick. It's write is just way to slow for that.
NM. I found it. Very easy to do with Gparted. Just right click on the swap partition and disable. Easy peazy.
Servo: 1002261 Jitter: 7811
Base: 33045 Jitter: 8721
The system really isn't to bad to use in this state. I'm going to start up with this configuration. Just wanted to kept a tab on my results. I'm surprised on the jitter but this thing has been running 100% Load for over 2 days and it took almost 10 minutes for the screen lock password to even come up it was so overloaded. I'm happy as sin personally. I also think I can saftly use these numbers without fear of any surprises.
