additive offset error
- M4MazakUser
- Thank you received: 3
07 Apr 2011 00:32 #8665
by M4MazakUser
Replied by M4MazakUser on topic Re:additive offset error
so it seems that when it warms up, all is fine. this problem was happening in december last year, and now it's cooling down a bit, so it's returned. i geuss it is either the encoder or the mesa pwm/encoder board having a hard time counting.
im using a HENGSTLER 5000 line encoder (rs components 260-3910)
and a mesa 7i33ta daughter board.
ill edit my config files and change to a spare encoder input soon to see if it helps.
- M4MazakUser
07 Apr 2011 01:45 #8666
by M4MazakUser
by the way, with a count of 444444.444444 counts per second (1mm = 3333.33333 counts) at 8000 velocity, this is well within the cards 10mhz read speed. and i limit speed to 6600velocity.
07 Apr 2011 02:03 #8667
Replied by PCW on topic Re:additive offset error
Sounds like something is marginal I would check
1. That the encoder 5V is OK
2. That the 7I33 5V is OK
3. That the 7I33 is jumpered for RS-422 inputs
4. That you are not exceeding the 300KHz max square wave rate of the encoder
07 Apr 2011 11:58 #8669
Replied by andypugh on topic Re:additive offset error
PCW wrote:
I get 366kHz from his earlier figures. Is that the configurable noise filter?
07 Apr 2011 14:15 - 07 Apr 2011 14:19 #8680
No that's the encoder spec, not sure if its a count rate or square wave rate, count rate would be bad, square wave rate would be fine...
Hostmot2 encoders with filter-on take 15 clocks to respond so maximum count rate on a 5I20 (33 MHz clock) is ~4.4 MHz and about 5.3 MHz with the other FPGA cards. This is configurable (downward) with a global register that sets the quadrature counters filter clock rate. but HostMot2s driver does not have code to access this register.
Last edit: 07 Apr 2011 14:19 by PCW. Reason: correction
- M4MazakUser
08 Apr 2011 06:39 #8691
by M4MazakUser
YUP! 300KHZ seems to be the ceiling thanks for the help on this. -this has only been an issue lately, new encoders can obviously exceed there speed limit, leaving you tearing out hair later on..
Time to create page: 0.295 seconds
