Joint following error
I'm using emc with a motenc card, and a 3axis milling machine.
Recently I updated to the latest version. Sience then the machine runs for 1 or 2 minutes then one of the coordinates suddenly jump to a random number (about 300000 mm) The machine stops with a joint following error.
This happens even if i don't move the machine.
There were no hardware changes, I installed the system from a live CD.
I have no idea what to do.
A quick google of motenc shows it might be a servo system.
I suspect an encoder problem.
Is it always the same axis?
It's good that it stops, but bad that it happens, I suppose.
What version of EMC2 were you using before? (We can look to see if there have been any changes to the Motenc driver).
Is this a servo or stepper machine? What is the feedback from the mill to the PC?
Yes, its a servo system. The error shows usually on the Z axis, but not always.
There are encoders with index signals but i dont use the indexing.
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?UPDATING
Also I would update to the latest version 2.4.6 if possible.
I installed it on a new harddrive from the live CD.
I have the old config on the old HDD just in case.
I'll try to update to the latest version tomorrow.
The interesting thing is that there were no changes in the hardware, except the HDD.
I'll put the old drive back tomorrow to make sure if its a HW or SW problem.
